Wats up people was doin some looking around an found this will someone who knows wat there doing give this a try please ????
Recovery Builder
Recovery Builder
I think we need to take the cwm4 we have been testing and port it to ver6. There is a problem with at least the /data partition, maybe more. I believe this is because, in cwm4, there is no was to implement an internal SD which is inside of the data partition. supposedly in this version, if i were to wipe /data, i would lose internal storage also. This is not so as of now. I can wipe, flash, backup, anything to the /data and the /cache partition with no change. This int.SD inside /data issue is not an issue with cwm6 i believe.
it will not work. we have a version floating around that has just a few problems left. IF you dont know where it is and how to flash it, dont bother asking because we only want people who know what they are doing testing this. if you follow the allthingsroot section, and know how to fastboot you could have been testing this.
