Root Clockwork Recovery Mod Loop
Ok I have the motorola Triumph. I changed the recovery.img flie. When I get into clockwork recovery mod and chose anything like instalzip from sd card it brings the rom manger image up and just sits there and doesn't allow anything to happen. I would like to put the miui rom on my phone so I am not sure what to do cause it's looping.
your pressing the power button to select the install option...
press the menu key instead :D
menu= select
back= go back
vol up/down= move the highlighter
People don't read the instructions anymore, before they install/flash/update stuff...
Psssh instructions! Its like playing with legos... You don't read the instructions... Although I usually actually do with android stuff cuz I don't want to totally screw up my phone...
