Root Clockwork Restore Stuck
murdoc158
Member
Doing a Clockwork Recovery advanced data restore and it's stuck at info.plist. Do I do a battery pull or what?
Just flashed the newest TBH GB updates, rebooted recovery, and did advanced data restore from my leaked GB backup.
Data usually takes a while. If pull battery during restore you'll have to .sbf. Did this mistake once
