Ok thanks, I was just looking into that, unfortunately it keeps erroring out, according to XDA "v2.2.1 is not (yet) available on rom manager (please be patient)."
hmm
Download this file:
http://db.tt/PEhJy41
Make sure it stays named PC36IMG.zip, exactly. Copy it to the root of your sdcard. Turn the phone off, then turn it back on while holding the volume down button. That will take you to hboot, where it will scan for PC36IMG files. When it sees it, it will prompt you to flash it. Once it's done, you will have RA 2.2.1. Honestly, though, if you just update ROM manager (or uninstall then reinstall it if it's giving you problems) you should be able to get it that way. Keep the PC36IMG.zip around anyway, though, just in case you ever need it. Just keep it named something like PC36IMG_RA.zip so that hboot doesn't see it every time you boot to the bootloader.
Cool, thanks. Ive always been lazy and used rom manager, but just in case i eff something up and i need it, ill hang on to that.
No i hear ya. I have had a few close calls but always worked my way out.Yes, I always keep a few PC36IMG files around for various purposes. Your phone is never bricked until you can't get into hboot. And if you can get into hboot, PC36IMG files will get you out of anything (ultimately - it's not that black and white, but still...).
And yeah, a boot loop doesnt mean you have a brick.
I was wondering how many 'bricks' we actually have from people upgrading to rls5 and upgrading radios.
A lot of posts were saying that there were bricks, but i dont know how many were actually bricked.
I wish i could find out, cuz i have a few friends that want to upgrade to rls 5 but are scared to do so lol
), you can't go wrong. I've heard reports that it sat at that screen for quite a while (only too mine about 4 minutes), but those who let it sit always had it reboot itself back to recovery eventually.You can't really brick a phone from just flashing a ROM. My understanding, so far, is that people who didn't understand the full process of upgrading radios didn't realize that the first reboot after running the radio update zip in recovery would take them to the htc update screen (black screen with green arrow). Since the process hasn't been a little more well documented until now, some people thought that meant something went wrong, and pulled the battery out. THAT will most likely give you a brick. If you just have patience (and a full battery), you can't go wrong. I've heard reports that it sat at that screen for quite a while (only too mine about 4 minutes), but those who let it sit always had it reboot itself back to recovery eventually.
Yes, you can flash back and forth if you want. Just remember that the more you do "risky" flashes, the greater chance you have to brick it. I'm not saying doing it over and over again will eventually give you a brick, I'm just saying it's not your normal day-to-day flash, and it *is* the type of flash that can cause a brick if not done right. You're probably fine though since you know exactly what you're doing.
As far as wimax is concerned, I've heard that a bad radio flash can cause you to lose your keys. Seems to happen mostly with clockwork. As long as you have the correct backups, you should be fine. You'll want to verify before and after updating the wimax radio that you have your keys, the MAC address stays the same, and, of course, the version changes (up or down depending on what you flashed). The wimax_mtd command from the terminal emulator will give you the last two things (and probably won't work right if keys are missing, too). You need su to run that, of course.
I havent checked in a while, but i just connected to 4g so im sure its fine lol.
I made a backup with the 2.6 clockwork so my wimax should be safe. I assume *if* i ever lose the keys, i just go to advanced restore and restore the wimax part of the backup?
That should do it. Of course, that's one thing I've never done myself. I'm brave, but not brave enough to purposefully wipe out my wimax keys just to see if a backup really works. It should, though.
