Root ClockworkMod Download links
Thanks for linking to my test recovery in your first link, there is a reason I didn't post it anywhere. Then only shared the link with a few people with apache being one of them. Where I have no clue why he didn't comment but off charging does not work with the first one you linked. Which means if someone lets the phone go dead it will very likely need another design/hero to charge the battery to get off that recovery.
The other one you linked is fine though.
I know where you found the link, who's site do you think it actually is :rolleyes: As I said the first link does not charge when off. As off charging is messed up, which means it will not charge if it goes dead.
The other link to recovery is the working ones.
Edit: Actually nvm, To the people that look in this thread. Do not flash the first recovery, if you did take it up with him. I will make a thread for my work and add the link here in this edit. Download the recoverys from here: http://androidforums.com/evo-design...-5-0-2-8-htc-design-4g-heros-aka-kingdom.html
Do you want me to pull those links for you ?
Well I have pointed out twice in this thread that the first link doesn't charge. Yet you seem to not understand how important it is to charge or have respect for dev's work you posted, that you were told had a issue. So you can do as you like, though when people keep downloading the first/testing one.
Then there phone goes dead and they think they have a brick. You can deal with that one as it isn't my fault. I said it twice and now 3 times.
