Help clockworkmod issue
ok so when i reboot my phone it shows the boot logo but then the screen turns black n stays like that. So i do a battery pull and when i put the battery back on
it starts with the bootlogo then the animation then to my screen. How come i cant go to the clockworkmod ?
If you want to load CWM without using the bootstrapper, then plug your phone into a wall outlet and reset it. CWM should pop up.
If you are loading into your home screen, then use Droid 2 Bootstrapper to reboot into recovery.
^ ^ so i uninstall the droid X bootstrap ?
No, just giving you two options to get to the same place. If you are able to load into your home screen, then just use the droid x bootstrapper to load into CWM. If you are stuck and can't get into your home screen, then use the other method that I gave you.
