TzuDohNihm
Was trying to flash CM7 again. Came from ROM manager so I assumed the checking of the wipe data and dalvik did that manually so iI applied the update from .zip, rebooted the system and got stuck once again in a bootloop. Pulled the battery and went in and accidentally hit backup instead of looking at my restore options. Got an error on /sdcard/android.secure.
I highlighted wipe data/factory reset and it made the blue choices screen go away and lit up the hat and arrow and then nothing.
Now any choice I make simply lights up the hat and arrow and nothing at all happens.
If I pull the battery and try to turn it on normal I get stuck in a CM7 bootloop.
I need my phone. Please, some help?
