So I flashed Axura today, and while exploring options in ClockworkMod Recovery, I came across lagfix options. I had no idea there were so many different lagfixes out there. Any suggestions on which one to use, if any?
Axura has a built-in lagfix, assuming you're running RC1 (the latest incantation of the Axura ROM).
So, there's no real need to apply one, but if you ever flash another ROM using CWM, you just scroll down to Select ULK (I believe it is) in CWM and that will open up a Lagfix menu with installables.
