Hi all,
Bit confused with this.
I'm wanting to partition the SD card with a 512MB ext 3 partition but having a problem following instructions provided here as my screens/options don't seem to match up with what's advised (no issue with people's instructions as I'm sure they're 100% right as they work for everyone else just not me
I've tried using ROM manager to do the partition, enter the settings(512MB, 0MB swap), it reboots to recovery but doesn't actually do anything. Just shows me the android + triangle image. If I press the power button, it takes me into clockwork. The log on the main screen says:
ClockworkMod Recovery 2.5.0.7
Finding Update Package...
Opening Update Package...
Verifying Update Package...
E:failed to verify whole file signature
E:signature verification failed
Installation Aborted
If I look in the menus in ClockworkMod Recovery, I don't have a partition SD card option either but I've seen people mention that it should be there. Anyone know why it's not there or what I can do to fix it? Is it my update.zip on the sd card that's the prob? I've browsed to the zip file on the phone and the contents seem to relate to ClockworkMod Recovery (nandroid and stuff).
I've also tried using Gparted on a live CD to do it. Got to the gparted window where I can see the laptop's hard drive but my machine doesn't see the micro sd on the phone even though I've connected it in recovery mode with the SD card mounted.
other than not being seen there, it is visible in Windows Disk management. I can see it in Explorer and browse through without any errors so SD card doesn't seem to be the problem(I don't think).
If it's of use, I'm running:
HTC Desire
MIUI 0.12.31
Android version 2.2.1
Baseband Vers 33.44.00.32U_5.09.05.30_2
Kernel Vers 2.6.35.9 (MIUI@MIUI #25 from 29th December 2010)
Any help is appreciated. If I've missed any info/settings that would help, let me know and I'll add it to the thread.
Cheers guys and gals
Elbee
HTC Desire
MIUI 0.12.31
Elbee
