An UrgeTo Dance
The Hero of the Winds
Okay so I was reading the rooting for dummies thread, and I saw that it said if you install clockwork recovery that the stock recovery is permanently gone, does this meen that I cant unroot if I root with unrevoked using clockwork or is that only if I use rom manager. The part where I read this was in the nandroid backup section under the through rom manager.
Thanks for any help.
