Valiant4Funk
I'm restoring my most recent backup using ClockworkMod Recovery v2.5.0.6, and I'm stuck on the recovery step. I'm new to rooting android, and only performed my first root last week.
My screen looks like this:
Checking MD5 sums...
Restoring system...
Restoring data...
browser.db
(\\\\\\\\\\\\\\\\\\\\) -the progress bar- is NOT moving at all.
And it has been stuck on "browser.db" for over an hour.
Here's what I've done...
-It's a droid X, running 2.2, recently rooted with Z4root (1.3.0)
-I noticed that android 2.3 was available, and I downloaded it.
-Before installing, I figured I would rename all the apps back to .apk (like blockbuster and skype) that I changed to a .bak file to reduce bloat, and then i used Z4root to unroot my phone. (all that so the update would apply properly)
-I then tried to install android 2.3, and my X rebooted, and said "update failed."
-I tried again, and ClockworkMod came up on boot. I figured I had ****ed something up, so i restored my last (and only) backup that i had made with ClockworkMod.
-and....well here I am. The ironic thing is that I have a bunch of calls I have to make. I'm almost tempted to pull the battery and do a factory reset....but I'm not entirely convinced that would work.
What should I do? I really would prefer to NOT do a factory reset. For current purposes, let's say that time is NOT a factor. Please help!
Restoring system...
Restoring data...
browser.db
