JasonCombs123
OK so when I went to the thread and people said that you can download stuff but not install so I have a solution.
So first download apkinstaller on another phone.
Plug in the device you used to get appinstaller.
Then extract it to your computer.
Then plug in the device with jb 4.2.2
Then put the app in a folder or SD card.
Open up a root browser and put it in the system>app folder.
Then reboot.
I think if you could somehow get to the system>app folder on a computer then do the same.
Hopefully that works but if not then o well I tried to help.
Or maybe I could make a zip and you could flash it then you could have appinstaller but I'll try.
Then reboot.
