CenterTurkHD
How to Install CyanogenMod 10.1
IMPORTANT:
**Read this post before flashing:
Read this before flashing ICS ROMs or above
**WARNING: If you proceed, you will lose 3G data speeds. You will have to do the FULL 3G fix whenever you switch basebands, the guide is located HERE.**
**If you already have a previous version of CM10.1, all you need to do is clear cache and dalvik cache.
Installation:
1. Download cm-10.1-20130719-NIGHTLY-u8665.zip from HERE. Download the ICS Baseband from HERE.
2. Download Gapps from HERE. Place all three .zip folders on your SD Card.
3. Reboot in to CWM Recovery.
4. Power off the device, then hold the Power and Volume Up buttons until you reach CWM.
5. Using the arrow keys, navigate to
