Root Cm10 running out of free space
jgriner
Member
I never had a problem with running out of space until I flashed cm10
Under storage it say I'm only using 300 megs out of a over a gig.
It wouldn't even save the screen shot is there a setting I'm missing?
It's probably the wimax/4G logs in the /data/wimax/log directory.
Flash this zip file in recovery which will delete and recreate that directory and then mark it immutable so no more logs accumulate and you should be fine.
ramjet73
ramjet73
ramjet, you are a saint. I've been having this problem too...I was wondering why a ~200mb rom was taking up 1.1gigs....
ramjet73
It work THANKS!
Should I not back up my wimax files when I preform backup what's in this file?
It work THANKS!
Diagnostic logs for WiMax/4G. Probably not useful unless you are debugging that code so I wouldn't bother to back them up. should you need to write to that directory without doing a clean flash of the ROM you can use this zip file to remove the immutable attribute.
ramjet73
been looking for this answer all day, lost a decent amount of data due to reformatting and still having this same issue. thank you so much
