Stikman
Member
hey i need some input and help with cyanogen mod
im currently running icarus 1.1 and ive seen that cm6/7 is supposed to be better, since im always looking for improvement i was thinking of upgrading so i ned help with these:
pros/cons of cm6
pros/cons of cm7
which is better cm6/or cm7
wats the best guide to install cm6/7
and looks is a big part of my choice so which looks better cm6/ or cm7 (if you had a screenshot of them could you post it plese
i guess thats all my questions for now thanks to all
also will i have to re install all my apps like i did with icarus? cause that would be a drag
pros/cons of cm6
pros/cons of cm7
)i guess thats all my questions for now thanks to all
