Root Cm6 Help! (screen rotate)
eman863
I flashed to CM6 this morning and everything seems to be goin ok EXCEPT for the fact that its not letting me rotate to txt or anything:mad:. Can any1 help? would be greatly appreciated.
use the search for future refs, but go to settings, tap display and make sure Auto-rotate screen is check....
Read the wiki, you may need to lock home in memory. Go to CM performance settings, also you may need to set the rotation to only 90.
