Root Cm7.2 release candidate
ChiweN
Android Expert
The guys over at cyanogenmod have put out the official cm 7.2. Its in the experimental downloads. It is stable thus far and should be moved to their stable releases any day now. :-)
I don't have time to link it yet I will do so later if colchiro doesn't beat me to it haha
Thanks for the link, I was not aware of that (but don't spend much time researching the NC anymore as I don't own/use one).
Bear in mind that several months can go by between RC1 and stable versions and the Mirage kang has several tweaks/mods that you won't find in the CM7 version.
I updated the CM7 guide. Does 7.1 RC1 show up in Rom Manager? If so, I'll update the quick'n dirty guide that used RM.
Did you mean is 7.2 in rm? Either way checking for ya now, gimme a minute.
7.2 RC is not in rom manager yet. But I just found something exciting on rom manager..apparently Ryan is back. A rom called phiremod returns is up in rom manager. Phiremod 7.2 has been released. Phiredrop is back :D
Thanks for checking. :D
When goo Manager is more dependable, I'll update the guides to include that.
