Root Cm7 3d boot animations
blaxican25
Android Expert
v2.zip
http://www.mediafire.com/?xtk3vsv3y73352l
to install from absolute system tools go to downloaded boot animations push far left button, import from sd card then push import to change import animation name then select done.
make sure to change screen resolution to match are screen size
go to boot animation.zip editor select animation you wanna use push far left button select edit dec.txt edit the first black line to match are screen resolution which is 320 by 480 then push far left button save changes when done go back to downloaded boot animations and select animation you just edited and restart phone thats it. 320 480 12 don't bother the third set of numbers.
that lil android dude has an invincible arm in the arrow-go-round one--keeps getting plowed into by the arrow lol
