Root cm7 and ext3
jdta09
I've just installed Cyanogenmod for the first time, beforehand I was using LeeDroid. Previously I had an sd ext3 partition which showed up in Titanium Backup for example. After flashing the new ROM it doesn't show up any more and I don't have room to reinstall all my apps. Does CyanogenMod 7.0.3 work the same way as LeeDroid and should it be used automatically, or do I need to repartition the sd card?
Many Thanks
