Root CM7 Battery Issues
I just started having a problem yesterday and i cannot figure out a solution. I have the latest TG CM7 build and was getting awesome battery efficiency. starting yesterday i noticed that the Gallery, Dialer, and Android System are using about 30% of the battery each and my battery is draining at a rate of about 20% an hour. I re-installed the latest CM7 beta (0.7) and still get the same issue, If anyone has and info on this i would greatly appreciate it. I have attached a screenshot of my battery usage so that you can see what i mean. Notice that i have used 40% battery in just 1.5 hrs
Thanks
Did you install any other apps just before this happened? For me I had the android Facebook app on for a while and that drained the bat big time...
Im having the same problem, but my FB or nothing is running. The greatest drain says that it comes from "Android System"... @ a staggering 69%
Same with me with Android System. I took my bathroom to the crapper and played Hanging With Friends and lost 10% battery in about 15 minutes....not kidding. I'm OC'd to 1.3ghz/SmartAssv2 but it shouldn't be that bad.
