Root Cm7 - headphones not working
bfranc
I use Pandora regularly with no problems with CM6 however I just flashed CM7 and now when I plug the headphones in I get the notification for the headphone on the status bar but the sound comes through the phone speaker only. Is this an issue or do I have a setting problem?
I don't know if it's constant problem or not. I was listening to Pandora, Using my headphones, and decided to make a call and then when call began (even the dialing part), NO SOUND. But as soon as I stopped the phone, the headphones worked again...
There is a newer 05042011 rom update that I am about to flash to. We'll see what happens!
I just got out the stock headphones for the Ascend and tried this (build 05042011):
1) I started Pandora and listened to some music
2) I went to the homescreen and went in the phone
3) I dialed *228 (I don't have service, so this is all I can do)
The music stopped and the call was placed. I was able to say "Roaming List" (so I was able to talk in the headphones)
4) I ended the call and it went back to my music.
So, as far I can tell, it's working just fine.
just test it with latest build, same results...:D
