First off all this is my own fault for being a bonehead and a Noob but here it goes: I recently discovered morphing and went kind of crazy themeing everything in sight. I installed lockscreen, basic,finishing touches etc. I then went looking for keyboard themes that I could flash and found several that looked good. For some reason the only way to install the keyboard was to move the native keyboard( via link2sd) to a user app and then move the themed keyboard(once flashed) to system via link2sd. I then deleted all the keyboards I didn't intend on using but unfortunately also deleted the stock keyboard that came with the ROM since I had moved it to the user app side. I later discovered that the keyboards I had installed lacked the text to speech mic And I also borked my navigation for whatever reason. Had to reflash the rom since the only Nandroid I had was with the new keyboard. Could not find a zip for the keyboard that comes with Harmonia 2.09 for the life of me. Lesson learned, never messing with flashable keyboards again
