A bit more than lag in my case - it would totally freeze on whatever screen it was on and not respond to any input. I'd eventually have to hold the power button to shut it down.A new install/upgrade is going to be laggy for a day or so until your caches are built up again.
I've used those apps on my DInc...don't they only do application caches? I'd be surprised if they took care of Dalvik.There are cache cleaning apps in Market... clear them, then reboot.
If it's laggy, I'd suspect the speed, brand, or reliability of the card.
Dalingrin said:We are in the middle of merging OMAPZoom framework changes primarily for OMAP4 device support(3D, new DSP, etc) but much of it affects the Nook as well. Media playback should improve somewhat for the Nook. Thus far I have new DSP codecs working but the overlay still needs some work.
The kernel commit that was finally merged is just some kernel clean up to eliminate possible causes of instability and SOD. No new features yet.
My 1st priority is to get the OMAPZoom framework changes merged because it affects multiple devices. After that I will focus back on the kernel hopefully figure out SoD and such.
Longer term, TI has been working on an OMAP3 2.6.35 kernel finally and I would like to look into that for the Nook down the road.
#150 looks good. Check out #4535 and after: [USER] CM7 General Discussion thread - Page 454 - xda-developers
I'm going for it.![]()
I'll see if she had any issues in a bit.
and of course plugging it in starts it up again). The next day, thinking it was off, she unplugged and eventually the battery was depleted.
OTOH, she won't charge hers unless it's below 50%. That's why I said it was strange to find her's fully charged.I had #150 -> #155 -> #160 -> #165... all without issue. #165 seemed a little slower, but that might have been too early after an install or just my imagination.
Wife used hers with #171 on it last night, just before I went to bed. I suspect it was another hour of Mahjong.I'll see if she had any issues in a bit.
#171 had a kernel update, which is just an updated screen driver.
Wife says it worked too well. Usually she has trouble with Mahjong crashing and was up waaaay too late.![]()
