tmette
Member
Can anyone point me to the RC 1.6.1? I'm having the bluetooth problem with my car's hands free sync and would like to try taking the Bluetooth.apk and using it for the 1.7 version, see if that will fix it.
If that doesn't work then I would like to use 1.6.1 since I need to use the bluetooth daily. Every thread from other forums I find as a download link are all updated to 1.7. Can anyone help me?
EDIT: Nevermind! I found it here:
http://goo-inside.me/cm/mecha/rc/
