Root cm7 settings not saving
G2435
cm7 setting not saving always reverting back i tried everything wiping cache and dalvik-cache,fixing permissions
Could it be an known issue with that rom? I mean, I don't know about that rom, but perhaps others have had issues with it? Is it discussed in the thread for the download?
I know sometimes those threads can be long, but also, sometimes a search from within the thread can reveal something?
And why aren't you running Thundershock?!?!? <<<-------just kidding :)
not sure wich version of cm7 the op is on, but cm7 for the most part is really stable. if G2435 is on the nightlies then that could be an issue.
cm has a bug tracker on their wiki that you can check if you want to.
I'm running thundershock 3.0 I don't know what happen lol. I can't find a fix and I think Jamie built off a nightly not a stable. Its okay its wont hurt nothing :)
