What do you mean "leave unchecked turn offHello, I am having same problem sometimes. Usually wifi connects in 1-2 sec...randomly scanning gets stucked and NOTHING helps. Reboot, check-unckeck wify-no way.
Ok, I solved the problem like this. Problem is custom wify apk gets stuck and scanning does not start. I installed Wifi Analiser. Options-check open wifi when program starts-leave unchecked turn off when quit program.
This will do and you do not have to kill the router or settings or phone. Hope it helps. Good luck!
Upvote
0
