ben1122a
Not sure if anyone else is having this problem or not, but it is pretty annoying.
Right now, I am running cm9 (3-20 build I believe) with the test gaming kernel. Whenever I try to open maps, it just lags, freezes, then I have to force close it. Whenever I try to navigate anywhere with the navigation app, it just hangs on the splashscreen and the softkeys stop vibrating untill reboot. This is very annoying, as I do go out of town quite a lot, and would like to have reliable navigation. Does anyone known what the problem is/how to fix it? Or am I the only one with this stupid issue
P.s. I have tried this with the stock CM9 kernel and the 2-23( i think) build as well. Same issue. It seems like the first boot after reflashing any rom, navigation works. But after rebooting, it stops again.
