Root CM9 ICS On Triumph
jmatherly411
Keep up the great work all of you working to bring ICS to the Triumph. I have flashed the most recent alpha version to my Triumph, I am very impressed with all the work you have done to make this possible. Looks very clean and actually usable as I just browse the internet when Im not around a computer or check the weather and txt message. It has almost been 24 hrs since I have flashed the ROM over no crashes yet guys, keep it up. Thanks to you all of you, you all should the ones working for Motorola putting out new firmware you guys do a better job than they do. They can't even put out a patch to fix a few issues that some users have experienced with this phone. Cheers ;)
