Root CM9 / MIUI Alphas (updated 03/20)
hroark13
Android Expert
Recognized Developer
For devs only, and people who want something to play with and learn from
NOT FOR DAILY USE
I shared this with Bloodawn and Kouma a while back, we really did not get around to fixing everything in them, and not sure if we can.
(Thank you Blood and Kouma for trying to help me with it)
The CM9 is compiled from source and runs a lot better than the first CM9/ICS port I made in my bunkered thread found here
http://androidforums.com/galaxy-prevail-all-things-root/479581-bunkered.html
The MIUI I ported from a ZTE Blade ROM and used files from my CM9 to make it work, the MIUI seems to run better than the CM9 to me
This is the the MIUI ROM I ported from, Thanks tilal6991
[ICS] [MIUI] MIUIBlader for the ZTE Blade [ROM] [UPDATED - 24/02] - Android @ MoDaCo
Maybe some of you guys can fix some of the stuff that I was not able to, mainly the camera, and other things
Androidianfan Home Key Fix
http://www.mediafire.com/?czirs12vy5e6xc1
MIUI Alpha 2B (Bloodawn)
http://androidforums.com/galaxy-pre...iui-alphas-updated-03-20-a-2.html#post4103691
CM9 Alpha 2 - fixed 3G and GPS, some new libs,- camera still does not work, has MMS issues, bluethooth not working
CM9_PREVAIL_ALPHA_2.zip
MIUI Alpha 2 - fixed 3G and GPS, some new libs,- camera still does not work, has MMS issues, bluethooth not working
http://www.mediafire.com/?ah5hmgg0ww3etp3
CM9 Alpha 1
cm9prevailalpha1.zip
MIUI Alpha 1
miuiicsprevailalpha1.zip
Here is the source code for the CM9, I am too lazy to put it on Github right now.
prevail_cm9_source_alpha1.zip
If I have helped you, and you like my work, please click on the Thanks Button and give my thread a rating by clicking on the stars above.
If you would like to buy me a beer cofee, you can click on the PayPal button
i wasnt able to try your bunkered cm9...but this version looks awsome..i am really enjoying playing with cm9..did you have any luck getting wifi to work? i know in the op you said 3g and of course camera dont work..but overall its nice to play with cm9 on the prevail...Thank you Hroark
wifi should work on cm9 and MIUI
check out the MIUI, i like it better than the CM9
downloading now..overall cm9 wasnt to bad though..im gonna post some screen shots for people who dont wanna flash..just to give an idea of how sick it looks
okay i got the wifi to connect after sevral tries...really didnt do anything special just kept messing with it..on and off..on and off..finnaly it connected and i can play now
The Miui ROM looks amazing, I haven't tried anything like this before, but I'm willing to put some effort in to see if I can help.
For the 3g problem, could it be an apn issue? I notice Johnny and I have gotten wifi to work by just toggling off/on.. Maybe that could work with 3g?
EDIT. Could it be just the icons missing for 3g? Made a few phone calls and sent and received some text messages..
where are you seeing this screen ?
I am getting the same screen. It comes up after installing the miui zip and rebooting the phone. It says:
Encryption Unsuccessful
Encryption was interrupted and can't complete. As a result, the data on your phone is no longer accessible.
To resume using your phone, you must perform a factory reset. When you set up your phone after the reset, you'll have an opportunity to restore any data that was backed up to your Google Account.
Reset Phone
Then even after the reset, that same screen comes up.
its not a problem with the icons, it just doesn't work. try using the browser or something and nothing will happen.
Same as Roguefoxx, I tried quite a few times and I still haven't got anything else but that screen.. baseband issue? i went back to EJ06 from FA19 just the other day..:confused:
home button wont work on cm9...you have to use the back button in order to back out of an app and get back to main desktop...you can also enable back button to kill the app by long pressing it........
ok so 2 people are getting this screen
how many people were able to get the MIUI to work ?
Switched back to FA19 and same results... i redownloaded the two so I'm gunna try again
Update: Tried again with the redownloaded zips and same problem..
are theese working rom's? meaning i can use the phone while have them installed and tinkering? im considering learning how to do roms and will theese help
I believe you can make phone calls, but they are alpha builds. Very buggy and 3g, bluetooth, camera and other things won't work at the moment.
But you can get wifi to work with some toggling.
i made some calls and sent some text
since there is no 3g no mms
Yeah I was just trying to get across that they aren't really meant to be used for daily use for someone that isn't all that knowledgeable about them.
