Root com.android.setupwizard?
oneeyeguy
I rooted my phone using Superoneclick and everything was ok, except i think i deleted lghome.apk.(my search button was not working right). So I decided to do a hard reset and start over, but when i did the setup wizard started, asked what language I want and then pops up an error "The application com.android.lgsetupwizard has stopped unexpectedly please try again" I have to force close it and the process starts over again. I cant get past that screen. I'm running an LG Vortex with android 2.2.2 on it. I have a titanium backup file on my computer and all the files from the phone that i could copy to my computer. But I have to get past the setup screen to put them back on the phone. The computer wont recognize the phone as a removable drive yet. Any Help?
Figured out how bypass setup screen! Now I can restore the phone from my Titanium backup dropbox link! --When the LG setup starts do the following procedure--
  • Press
How did you get past the "The application com.android.lgsetupwizard has stopped unexpectedly please try again"? Your help is greatly appreciated.
my android does not go to home screen it says process com.android.lgsetupwizard nothing works only camra and music cant go to settings to do master reset and does not appare on my computer help!!!!!! i have and lg android os GW620
Hi I got a Samsung Exhibit II 4g 2.3.5 and I was putting a new ROM and I guess I pressed the wrong thin and now that setup wizard window won't leave my screen won't show can some one help me......
  • Press “Volume Up.”
  • Press “Volume Down.”
  • Press the “Back” button.
  • Press the “Search” button.
THANK YOU, I thought for sure I had really done it this time untill I came across this advice and it worked like a charm.... You Rock,
Go to recovery mode clear cashe partition then factory reset then boot wait about 5 min tap the force close If you can get your camera to go on take pic send it .it will have you log into your email .wait a couple min you will get a email .from an other device send yourself a link to the app store
