compacitive buttons light issues
I bought the HTC evo v 4g and I realized that my home button is not as bright as the other three buttons...
Is that normal??
Mine have equal brightness, does changing wallpapers make any difference? Mine has a small amount of light leakage in that area, changing wallpapers makes it less noticable.
I tried changing the wall paper but it is still the same...
Might be a light shortage??? Idk...
Should I go and get a new one?? I bought insurance for it..
If it really bothers you then yes you should return it. However if it's just a slight cosmetic issue and the phone works flawlessly? I mean that it's your money so how much does it bother you?
