Help Companionlink not syncing all tasks!
DEG
Have installed companionlink on my HTC desire, whilst it is working ok it does not sync every task from outlook and there doesnt seem be be any common link between the tasks it misses. Any ideas?
I used to use Google Calendar Sync myself. Installed it on my work PC, and it would sync my Outlook calendar events to my Google calendar.
  • Like
Reactions: DEG
It sounds like you've run into some strange behavior. Have you tried contacting our support team for help? They should be able to get things straightened out for you!
- David Z
I have exactly the same issue and your "support" department gave me lessons in how to turn my device on. I wouldn't hold my breath for a solution.
I have just installed companionlink and I face similar problem - could you please let me know if you get the problem sorted?
