davoid
Android Expert
Hi,
As a relative noob, I still have several questions, or blank spots in my knowledge that need clearing up.
So far, with the help of this forum I have managed to root and s-off my Desire
and thank you all for helping me with that!
Now, I haven't flashed a ROM yet, because I am unsure about whether I should repartition my memory table BEFORE flashing a ROM. Is this the case? And if so, should I flash the rom IMMEDIATELY after flashing the partition table? (I'm guessing that my Stock Sense system won't fit into my intended 100Mb system allocation) Or should I flash a new rom on my stock partition table (250Mb system) and THEN flash the partition table to a smaller size?
I want to save memory space while installing a fast rom, and I was thinking of flashing the Alpharev Oxygen r2 which would give me 100Mb system space. Then I was thinking of, say, CyanogenMod 7.03 Light as a suitable rom for this system size. Would this be ok? (Also, is this a fast rom compared to, say, Oxygen or redux?)
And finally (I wish
), I am thinking of flashing an eviollets kernel so I can save power by reducing CPU voltages and extending frequency range. Would this kernel (either ManU 1.4 or 2.0) be compatible with the CyanogenMod ROM, or would I need to use it in conjunction with a different ROM?
Oh, I almost forgot. I've just found out that the newest release of Oxygen (2.2) is too large to fit into the system space of the Alpharev Oxygen r2 table. Is it likely that Alpharev will release a new table or would it be worthwhile learning how to flash custom MTD and flash a non-standard table so I could try Oxygen? (I was considering trying oxygen 2.1.6, but upon hearing there was a new release it put me off trying it, in favour of the newer release, while I don't want to waste memory by flashing the Alpharev CM table in order to fit it in.)
I'm sorry for asking so many questions in one post but I thought it might make it easier to clarify my concerns if kept all in one place.
and thank you all for helping me with that!Now, I haven't flashed a ROM yet, because I am unsure about whether I should repartition my memory table BEFORE flashing a ROM. Is this the case? And if so, should I flash the rom IMMEDIATELY after flashing the partition table? (I'm guessing that my Stock Sense system won't fit into my intended 100Mb system allocation) Or should I flash a new rom on my stock partition table (250Mb system) and THEN flash the partition table to a smaller size?
And finally (I wish
), I am thinking of flashing an eviollets kernel so I can save power by reducing CPU voltages and extending frequency range. Would this kernel (either ManU 1.4 or 2.0) be compatible with the CyanogenMod ROM, or would I need to use it in conjunction with a different ROM?Oh, I almost forgot. I've just found out that the newest release of Oxygen (2.2) is too large to fit into the system space of the Alpharev Oxygen r2 table. Is it likely that Alpharev will release a new table or would it be worthwhile learning how to flash custom MTD and flash a non-standard table so I could try Oxygen? (I was considering trying oxygen 2.1.6, but upon hearing there was a new release it put me off trying it, in favour of the newer release, while I don't want to waste memory by flashing the Alpharev CM table in order to fit it in.)
