Mine just shows as JuiceDefender 3.2.9
That's the stable version. The beta is on 3.7.9 or something. I just uninstalled it as many functions there were not working as they should, and the menu for chosing profiles was not stable. But this I have now seen, also seems to be a problem for the stable version.
All in all, first glance, this program is poorly made and MANY functions require a rooted phone, which I am not happy with. Also for a European stock DHD, it cannot control 3G communications it seems, as it claims the ROM is not compatible with the AOSP helper, and that I should install the Cyanaogen mod
So it does not disable mobile communcations as it should, meaning for me it is practically useless then, as I already have a low screen brightness, don't use Wifi much (and that is already battery saving compared to 3G) and lock/timeout time.
Also the log seems to go haywire sometimes, and multiple times displays "WARNING All settings are reverted to default!", but nothing was changed by me, and the profile I chose (Costumize) seems to still be active.
Furthermore, it seems like that with all the activity monitoring, and logging, that the program actually will suck up more juice than it saves for me
However, I have just installed it, so I'll let it run for a while and see how it goes. But first impressions, are NOT good
EDIT: Seems like the Juice defender can still control some aspect of my data communications, as when my phone went under 15% battery yesterday, Juice defender kicked in and deactivated mobile data communcations while the phone was locked. However, I am not noticing any noticable effect on my battery usage while the battery is over 15%, which is slightly disappointing =/. I'll continue to conduct the test
, however my only use of this program as far as I can see, is if the phone is rooted and I can then set a scheduler for the night & weekends. However, I am not willing to root my phone, as it is an expensive phone, and I want my warranty&guarantee and support from HTC. I wish to use HTC services and apps as they come out in the future, and if something does not work as it should, HTC will not lift a finger for me if the phone is rooted
