Compromises to improve battery life
rjglenn
Everyone is always complaining about the battery life on these phones. Life is full of compromises, and here are a few to greatly improve the battery life on your commando.
How many of you need to be notified of new emails immediately? Go to settings>wireless & network settings>mobile networks and uncheck data enabled. Yes, your data will not work with this box unchecked, but unless you need immediate email notifications or a data connection while your phone is in your pocket it will be okay. This will greatly improve your battery life. If you want to check your email or look up something on the Web then recheck the box.
Another thing you can do is turn off GPS and sync.
GPS: Does your phone really need to know where it is at all times?
Sync: Unless someone else is updating your calendar or you are updating a bunch of contacts no need to have your phone constantly resyncing information that hasn't changed.
Screen brightness: Turn in all the way down. Still plenty bright enough to make or take a call and read a text message.
All the above, 17 hours, 78% battery left. YMMV.
So I am currently at 77% @11 hours, this is counting 2 hours of slacker streaming over wifi and some weather tracking with the GPS on for about 15 minutes. I'm sorry to say it but if you have to disconnect your mobile data in the network settings to get that performance you must either have a really super cool launcher or some jacked up apps, 12 push e-mail accounts and a live photo album connected to every social network on earth.
I have found that by running basic, trust worthy widgets and, 2 E-mails (Gmail and hotmail) and keeping junk like social beat disabled, auto brighness and sync on all the time, I can pull down more than 2 hours to a percent of battery drop on average with little usage, with moderate like today I burn up closer to 2% per hour reversing the ratio but to have to cut the data cord to you smart phone means you might as well not have it IMHO.
At night while I'm sleeping I disable sync on the power widget and get like 4 hours to a percent, I also have noticed that I have cut down enough junk that if I go into the graph on the battery usage monitor I now have zero awke time while I am not touching the phone, the WHOLE time, 8~ hours. I believe this is the critical fact that leads to my seemingly longer than usual battery life, it took me about 2 weeks of monitoring apps and widgets to find the right combination to get my weather, e-mails, updates, and sunset/tide, to be accurate enough yet not wake the phone. It is possible to carry a SMART phone, that knows what you need to know, the instant you turn in on, without fiddling through 4 layers of menus, and still get multiple days of life on a charge. Personaly I like to plan ahead just incase I get stuck somewhere so I charge my phone every morning for 30 minutes while I shower, jog the dog and make my coffee and lunch before work, thats the only time it sees the charger until the weekend and then its a "whenever, if i get around to it" scenario unless I'm on duty.
Not to cut down too much on rjglenn, what he said is very true, if you switch your smart phone into a dumb phone manualy every time you use it, it can save tons of battery, if you are a social network junky this might be the way to go, but to save yourself the hasle of menus try juice defender, it disables your 3g radio on screen lock if you set it to, and you can set it for that and nothing else and it makes leaps in battery life, I set up a social junky buddy of mines GS2 (which are known for terrible battery anyhow) that way and he went from ~11 hours to ~30.
Good luck with your battery adventures,
John
This is completely off the topic of battery preservation,
but do you know approximately how much data is used streaming Slacker for 2 hours?
(if done on the 3G connection of course) ;)
I've wanted to use it at times,
but find myself away from a wifi connection in those situations.
I have a limited 2GB plan, so I obviously dont want to go over due to music,
or run it up so far to where I dont have enough when I need it for something
more important like navigation.
Rjglenn, everyones battery could last that long if they pay attention to what things are doing in their phone, not just me. Your post is useful and is exactly what one should do if they need their phone to last a while, right now, and troubleshoot later. If you dont want to troubleshoot or sacrafice a certain widget there is an app I mentioned that does exactly what you are doing that can save a decent load of battery with more convenience. ALOT of users of android have battery issues so finding info on that is not hard.
Blacktooth I dont know exactly how to isolate how much data it would take for 2 hours honestly, the usage as per vzw doesnt update that quickly. If you have an idea how, I'll do a 1 hour bench mark fro ya on my way home from work.
John
John,
I don't run any widgets, I have two email accounts and I am using the enhanced email app for these two. I don't have any social apps running and have uninstalled the "social beat" app on the phone as well as just about everything else that Verizon had on it. I do live & work in areas with marginal coverage. I am in a rural area and there is no Wi-Fi available. Here in rural North Florida in the formally Alltel areas Verizon runs voice on 800 & EVDO on 1900 so my phone spends a lot of time looking for and connecting to the EVDO channel. Now it does not. I work shift work - 24 hours at a time - and I need the phone to be able to last that long per charge. I don't need instant email notifications, but I need to be able to check my email. I don't need an always on data connection, but I do need internet access. I rarely update or add contacts, and I usually update my calendar once a day. No need to keep that sync going either.
What I do need is to be able to make and take calls, and send and recieve text messages for 24 hours at a time without a cord.
I would love to know your exact configuration since it seems to work very well.
Rjglenn
Knowing that you're in a low service area you have definitely started to get down to the correct methods to stretch that battery. Your lack of service is definitely a different situation than mine, when I get out of 3G I'm usually out of 1x also, Verizon up here (upper peninsula Michigan) has 2 towers in my stomping grounds, both are 3g, once I lose those I just go to airplane mode and hope I have enough info cahed to find my way back with maverick and standalone GPS. I'm usually out in the woods shooting/hiking/running the dog or out on a boat for work when these scenarios arise.
Your set up is very similar to mine as far as stripping down and disabling the social junk and running just push E-mail. I have Google sync disabled via the dialer unless I have recently added something to the calendar or gotten new contacts with E-mail addresses then I will sync manually. I do use backup assistant and have it configured for update in the late afternoon as that is when I am usually getting home and can just about guarantee I have service so it won't start a wakelock searching for service. Honestly my configuration probably won't work as a blanket so I have a process to get the mileage out of my device and others in my close group of friends and family, they are on an array of providers not just VZW here it is;
In your situation I would start like this: #1 Go to dialer>*#*#4636#*#*>phone settings>scroll down to preferred network type>try "CDMA only" mode for a day, it should disable 3G. The setting I am on (and I believe is stock) is "cdma auto PRL". You won't run on CDMA only forever, if it works for your daily needs while you are in crap areas you will probably want to find a program or widget to control this for you in a later step. You should also try a day running "GSM/CDMA auto PRL" this setting should allow your phone to jump from cdma (VZW) towers to GSM (ATT) if CDMA is not available, from my understanding if you run GSM/CDMA auto you should also set settings>wireless & network> Mobile network> system select > auto. I have this set to home only as my work is literally 300 yards from a larger Canadian city but I think you could risk it all the way down there in FL. *Note for GSM/CDMA auto, I have heard of people up here near the border getting the "allow roaming access for this trip" message often when the GSM/CDMA is set but I have also heard from people in northern nowhere Oregon say they get better service that way and never see the roaming message. Now that you know which mode works best for you, if it's CDMA only, set it back to auto and go the the next step, if it was the GSM/CDMA auto you can most likely just leave it and move to step 3.
#2 Once you have done a couple tests on your radio settings, find an app or widget that can set the mode for you at your convenience, remember screen time is battery time: "Juice Defender" is a program that can do it automatically, only searching for a network while you have the screen on (may need ultimate if you want to configure data on or off on a schedule) but can do more that may not be needed and is a largish download. I have leaned towards this one on my wife's phone and a buddy here at work, I have them use it simply because it downs the 3g so push notifications from social networks when the screen is off, cutting down on wake time, I suppose it would be a similar situation with searching for service.
If you can't find a way/app that you like with CDMA only or GSM/CDMA auto you could make your method easier by using; "Mobile Data On/Off Toggle" by free wing, simple widget (or in one case a shortcut that acted as a widget) that will turn on/off mobile data from a home screen, its tiny (like 7KB) and appears to be the safest free version for CDMA phones, it essentially reduces your original step to a single click. Verizon is so much better about having service than the others (usually) that only 1 in 10 or so 1x/2g/3g toggles actually work on CDMA so go big red...
#3 After minimizing signal search, the next step in my configuration is to search for culprits of wake lock, anything is capable of waking the phone and you need to be the detective here. If you open your battery usage monitor (I actually assigned mine to the tactile key at one point for easy access) and tap at the top where it says #h ##m ##s on battery the graph should go full screen and at the bottom you will see timelines of when things were on or off, if you see blue speckled around all over the place under awake that doesn't line up with the screen on bar you have problems. You need to figure out what is; A. receiving or sending data automatically with or without a schedule (my 2 things are weather once every 3 hours and backup assistant once in the evening, out of the box I had several things going crazy that I just said the hell with and disabled like google sync in the dialer and the social stuff.) B. Polling a sensor (courtesy flip programs, vlingo in car audio cues, pocket quiet etc, luckily the commando didn't come stock with these programs but I have dabbled with them) C. Auto task killers, they are pretty much the android devil, if you disagree that's ok, I don't want to start a flame war so don't blast at me for that one but I assure you if you are using one, someone could find a better way to save battery with a little research. (juice defender is not a task killer, it is a radio killer). If you can't find your culprits there are programs to help, they do use extra battery but they can tell you what turns on when so you can take corrective action, then get rid of the battery draw/wakelock monitor program also after fixing your issues.
If you go through these steps you will likely get great battery life, my "compromise" was time to learn about the OS and how to make my device work for me, not to have to work for it for the next year and a half until it gets scrapped. I also compromise on my apps choices, my apps don't all look pretty but they do the job I need and don't constantly load ads or cause issues.
Rjglenn, I appreciate your start of this thread, I don't claim to know everything about android and I'm sure a true super user has better solutions than mine but for non-root devices I think I have figured out a bit about battery, in your low service area you definitely started to figure out exactly what to do, and if you like to do it manually every time you pull out of your driveway that's cool, I like my smart phone to run alone intelligently. I can't simulate your situation but I hope my process helps in the long run.
Good luck, if you want more specific info about my setup/location/usage etc just PM me, John
This is all very informative and thanks to all for taking the time. I was wondering if there was maybe some shortcut/toggle to kill data quickly.
FWIW: I have been using the 1800 extended battery for over a month now and was kind of wondering how much it really helped so I went back to the oem for a day or so and was amazed at the difference. Not scientific testing at all, just my observations for my personal usage which is quite similar everyday. In any case it was night and day difference. I think I was getting to accustomed to the 1800 and thinking it was not that much better, but by switching I quickly found my "normal" usage would not get me thru the day and the 1800 while mostly exhausted by days end at least does get me thru.
This is with all settings enabled except GPS, full bright, instant email etc.
Those are all good tips above tho and thanks to all the posters.:)
I say thanks to ya both.
RJ,
I see the info that you were providing for what it is:
A nice set of quick tricks that can provide immediate results for
users that don't want to necessarily get too technical.
That's me in a nutshell. :cool:
I've been using those methods religiously since I got the thing,
and for me it's just the easiest way to go. :D
John,
You seem to have really dug deep into finding out how
your battery is being used, and have provided great direction
for others to take in getting the most out of it if so inclined. :)
I think this discussion will help each type user well with their power preservation needs.
John
Yeah...Verizon's data app is useless for anything needing to be close to real time usage.
I don't know how it could be quickly measured either.
I agree...and hate to limit/spread/choose what data i use each month! I listen to music but mostly downloads...no radio! I use Verizon's (small) data widget to keep an eye on my monthly limit...displayed on screen. I have to click on it to update the amount after downloads/use because many of my updates/syncs are turned off during operation to conserve battery power. I've been using JuiceDefender Free for my battery but have been considering the paid version on account of the custum & advanced settings!
I use K9 Mail and set it to sync never, then i tell it to check for email when i want to check, i don't turn on the GPS unless i need it, and WiFi is only on when i am home. Bluetooth and Data are on 24/7, i use a headset about 99% of the time.
I usually grab it off the dock at 8am, when i turn in around 10pm it usually has around 15-25 percent of the battery left. I haven't got caught with a dead battery when i need it yet.
