Before Gingerbread I had no problems looking at my Droid Charges SD card or transferring to/from. Now I am in a constant loop that gets me nothing. The strange thing is that I can open up ADB and my device is there and I can browse the folders and list files in them.
When I connect via USB, it does not ask Multimedia or Mass storage and when I pull down the notification and touch the Mass storage or USB symbol, the phone dismounts my SD card as if I wanted to take it out.
How I am set up:
Settings > Applications > Development have USB Debugging checked
Settings > USB set to ASK
Full cycle of what happens when I connect to computer:
I get a notification from my firewall that some program TO DO wants access to the internet. I go into Explorer and see a drive J with verizon files in it.
So I let the program TO DO run and the files in J are executed and drivers are installed. The results.
I disconnect the phone and reconnect it and sometimes there is a drive J with the files in there as before, and other times nothing.
I go to phone while still connected:
Pull down the notification bar and see this
I open either one of the USB listings and get this screen
I touch the connect to PC bar and get this
Then I hit OK and get this
And it just spins and spins and spins and nothing happens. When I back out and go into settings > SD card & Storage I see that my card is unmounted and have to remount it.
I am rooted, I used the Kernel imoseyon_kernel_charge_gb_4.0.0 from this site. http://www.toms-world.org/android/
ODEN does see my device while connected.
Not a total disaster I use AllShare or Asrto with the network plug in to transfer files between computer and phone or the other way around, but I really may need access on the computer sometime.
What should I do to see the SD card?
How I am set up:
