Help Concerns after changing rom/theme!
Lionblade
So I figured out all the problems I was having and used Launcherpro to apply docks and the theme is working fine. I have a couple concerns though.
I liked the stock incredible keyboard because of the option to minimize at the bottom left and also able to hold down a key to get an alt character (like k for ?) without have to press an alt. char button. There a way I can get that back or modify the one in place with another?
Another concern is battery. I looked at the battery usage settings and Display is taking about 74pct in comparison to everything else. I dont know why but it seems to be draining my battery. Is this a side affect of the theme? I tried adjusting brightness but it fcs every time even after reboot. Im using sonnysekhon's Lucid 4.0 theme, cm6.1 RC2 and LauncherPro. Any help is appreciated.
