Chris Maxwell
I've had my Galaxy Note 10.1 for two weeks, and I'm still learning. I love it. I'm enjoying it and using it for lots of things, but the real deal-maker for me was the S-pen and the ability to input via handwriting and have it transformed to text.
Thanks to a demo I found on YouTube, I have been able to use the GN the way I want. The video is at
Galaxy Note 10.1 - Handwriting panel demo - YouTube
I use complete recognition, as in the video, which (after testing the various modes) I prefer over stroke recognition. My problem is that I write small, and the words that are retained on the handwriting panel are much bigger than my writing, so if I pause very slightly and the words are generated, I find myself writing over the words (because the stylus is where I paused and the larger-size generated words have overtaken it), which confuses me and sometimes leads to errors.
I have noticed that if I fill up several lines, the generated words sometimes get smaller on later lines, eventually to the point that they're similar in size to my own handwriting, which works well and lets me write much more naturally--but the only way to get that size seems to be to have several lines of generated text in the handwriting panel. And it doesn't always work. Sometimes the font stays larger, and occasionally it gets really large on the lower lines for no obvious reason. I have no idea what governs this in the software. The fact that I can sometimes get smaller text suggests that it should be configurable, but I can't find a way.
If you use stroke recognition exclusively, this description probably won't make any sense to you, because with stroke recognition, what you write goes directly up in to the application and doesn't generate words on the handwriting panel. But I like the ability to do some editing/fixing in the panel before the words go into the application. I just want a smaller font for the generated words.
Anyone know of a way to configure the handwriting panel for this?
