Root Confused MTD
InfernalByte
Android Expert
Last night or was it yesterday my phone freaked when I asked it to do something and I ended up with a bootloop and I RUU'd because I was goin to waterproof my car. Lucky I did because it rainin now. Anyways I now got Alpharev CM7 table and I ave 2.1Mb free in the system partition. Good, but I have 187Mb free somwhere according to system panel, and a low mem warnin flashes up because I only have 36Mb left according to the status bar.
So you have the CM7 and custom MTD applied?
What does Quick system info say about partition sizes?
Take a full titanium backup
Best bet is to fastboot flash recovery (unmodified version), format system, data, cache, flash rom fresh and titanium restore. Then you're back on just CM7 hboot.
Na, there be no custom table just CM7 an I don't know where 187Mb free is so that I can customise it. Quick System Info doesn't say I think it must be a secret. It does however tell me that I have 782Mb a2sd!!!!!! Is that automatic now because I didn't flash it?
Tight fit. Are you sure you haven't restored a nandroid taken after custom mtd applied?
Nah is all fresh, I flashed DT an now I can't move the Dalvik either! TU is not recognisin a2sd. Am waitin for electricity before I wipe an try fings in a more sensible order.
DT? oh dark tremor
DT. Yup. I tried Miui a while back with ext4 and I don't think it does the card much good, as it became unreadable even to Gparted. As I tryin to explain to marky something in another thread, running it by a hex editor and re-writing the boot sector (aka makin a gold card), might just make it good again.
It worked for me.
