Root confused please help!
venom21
im rooted have 2.2 on my phone and S-off. what is the next step for flashing a rom? im a little worried that i might mess something up and have been reading for a few hours but i see all these things about the NOV update that confuse me.
i had root and my phone froze and deleted links for apps so i had to do a factory reset and was back to square one.. i rerooted and now like i said have 2.2 s-off and radio 2.15.00.07.28
my question is what is PB31IMG? do i need to install it
should i downgrade and reinstall the zip a different way?
whats the next step for flashing a rom onto my phone? thanks for any help you guys give me
ok also the build number is 3.26.605.1.
gracias. i just wanted to make sure i had all the requirements to safely flash stuff on at this point.
