connect battery life
kiroshi23
i just got this phone yesterday and went in thinking about how bad the battery is and it would not give me a day of use. but i was vary happy that in at 20h in and still got 31% left. all i did was turn 4g off when not needed (in other words eveything is off)
finished charging at 7pm and loaded some web, and 1 youtube video (normal use of web)
feel asleep at 10pm-9:50am still lots of juice about 85%
from 9:50am- 3:53pm i played about 15 min of angry birds, used web, played about 2 youtube vids and im down to 31%
the only time battery went down a little was when i was playing angry birds. but this phone gives me a day no problem. next time ill play a lot more angry birds and see what i get.(by the way with everything off and in standby i checked every hour and it only droped 1% each hour) sooooo happy:D:D:D:D
Yeah if you barely use the phone for anything the battery will easily go all day.
Try streaming videos for an hour on 4G and see how it holds up.
I have used the phone for 2 month already and I found he make it go longer without getting another battery. The LG phone is OK. The problem is Metro PCS software (such as My Extras, Polaris Office, Easy wifi, etc) that are in constant communication with their bases. They are a type of "harmless" Spyware so the can send you little commercials windows. ( as you have seen many times).
To removed this programs you got to know how to get in the phone or go to a authorise dealer and they will remove it for you.
WARNING: Your factory warranty will be void after this.
This will give 35% more battery life :thumbup:
yea so i played angry girds space for 1 hour and 30 min and it went down 35% (everything off and no tampering with cpu just in case anyone asks) i still think thats oky for a phone. i would like more but its oky.
4G on during that time?
and you drained more than a 3rd of your battery playing angry birds for an hour and a half with no 4g, background data, or GPS?
yeah that stock battery sucks and you might even want to think about getting a replacement. you shouldnt be loosing that much juice with everything off just playing angry birds.
hmm i dont think its the phone i have no problems with it. i think its the battery but its oky till i get a good slim one.
Yeah, it's definitely the battery. I have the 3850mah right and I'm almost 5 hours in with a little over half my battery left with 4G, background data, and GPS on the whole time. I streamed the radio for an hour and a half of that time, maybe 20 minutes of angry birds and a few minutes of web surfing.
I also have all "bloatware" installed. I only have myextras frozen because I hate that app.
i disable this app myextras from the app itself.. is that the same thing than freeze an app??
I hope that this is just the first run of the battery as I am not at all impressed with that life as I am now getting between 12-17 hrs with the 3500 battery and I keep 4G/WiFi running all day and I use the WWW and stream Netflix quite a bit. I just charged my new 3850 for the first time and will see how it does the first day also and report back.
lol w i think we could have had a misunderstanding withe the angry birds thing, it didnt go from 100 to 35. 35% was what 1hour and 30 min of angry birds used.(so that would be from 100 to 65)
I understood you clearly which is why I said you lost over a third of your battery.
Do you also have background data and GPS on? Are you underclocked? Do you get live sports updates or anything else that collects data in the background?
When you say 4G/WiFi are you saying you run both at the same time or switch between the two?
No I do not know how to do any of those things. It is simply a Metro PCS LG Connect 4G and since I do not get 4 G in my home, I rely on the WiFi as I have a nice cable speed and it seems to work with the Connect well. If I leave my home then 4G indicators come on and it works fine too.
That would explain why you get a few more hours than I do. I'm on 4G the whole way with everything on.
I get crappie 4G at work so I used wifi instead today to stream iheart radio. I'm 8 and a half hours in and I have 46% battery left.
I was just watching 3 hours of Netflix and my battery went from 43% to 5% and so now it is charging again.
One thing I have noticed is that my car charger does not work on the LG Connect 4G and it worked on my other LG phones so do I need to buy one specifically for the LG Connect?
Wouldn't know about it but I've heard people say they've had issues with the car chargers overheating.
hay when i surf the web or charge the phone does not go above 38c but when i play games shadowgun or angry birds space it goes up to 40c and when charging and games it went up to 42c. should i and can i get a replacement in corp store. if so how should i go about this
are you still on stock battery?
if so you're not gonna get a replacement thats gonna remedy that problem without getting an extended battery. under heavy use that battery is gonna get hot.
mine had gotten as hot as 109F and i've never played any games like shadowgun or deadspace. just angry birds and FF1 on emulator.
so i should just buy a diff battery
if you dont want the hunchback you can go with the 2430mah slim battery but no one has reported back with battery life or temp results.
I had this issue with the car charger. I bought a usb car charger with a higher output and it solved my issue. The old school style charger which work on my old esteem first version of it and ever other micro usb phone would not work on the connect. With the higher output of the new charger all seems fine now.
Hey W - I'm thinking about getting the Connect but doing my Homework on here first- I appreciate your Posts and tips .
Exactly where did you get this extended battery ?
Thanks.
