Help Connect to Overdrive app using Bluetooth
Hi guys :) looking for a way to listen to podcast or books (overdrive from market) using my bluetooth headset. Is there a special setting that I'm missing.
thanks
need more info.
is the book or cast playing? is your headset paired and doe sit show as connected in the settings screen? should be media audio thats enabled under the bluetooth settings screen on the handset.
have you been using this app and it just stopped working? or is this your first time using the app?
what headset are you using? do you have access to another headset?
