Hi all,
I just bougth my first droid, a HTC Wildfire S, and am having problems getting this thing to work on my home wifi network.
A quick overview of my home wifi setup:
- I have a simple SpeedTouch 516 modem that connects to DSL (this is not a wifi router)
- Then my wifi router connects to this modem, and broadcasts my wifi signal, with WEP security and MAC filtering (both wireless security and firewall)
- The reason for this somewhat atypical modem+router setup has got something to do with our ISP's digital tv signal, that the wifi router can't properly deal with. The setup is in place for a couple of years now, with multiple WinXP and/or Win7 computers successfully connected to it, a well a HTC Touch 3G (Windows Mobile 6.1). I'm not sure this could be the reason for my problem.
My Wildfire is able to connect to the wifi router, but I am unable to browse or go online using any app.
I have already tried the following:
- connecting to other wifi networks - this works as it should
- changing the wifi router security settings to WPA2 - didn't solve the issue
- removed the wifi router security setting (no WEP, no WPA, no WPA2) - no luck either
- also removed the MAC filters and enabled SSID broadcast (very unsecure) - still no luck
- tried surfing to 192.168.1.2, which is the config of the wifi router - works!
- tried surfing to 192.168.1.1, which is the config of the SpeedTouch modem - also works!
- tried surfing to google.com, didn't work
So, as soon as I'm trying to go beyond my SpeedTouch modem, things stop collaborating. I'm about to pull my hair out; I honestly don't know what to do next.
Has anyone got any ideas?
Thanks in advance,
Fr
Thanks in advance,
Fr
