Grrrmachine
Hi everyone. I've got a project on the go which has reached a point where I need advice from more experienced people. I hope you can help.
I've installed Android x86 on a netbook, so it works as a tablet with a 64Gb drive, wifi, bluetooth etc, but no mobile data connection. This will be installed in my car as my entertainment system. And I've got my Galaxy A5 phone, which usually carries all my music (30Gb+), plus email/net access.
I'm struggling to link them together. USB cables are completely redundant - the netbook doesn't see the phone as a USB storage device so I can't transfer files, and USB tethering doesn't seem to work either so there's no mobile data between them. If I set up a wifi hotspot for data, then I can't use wifi for file transfer, and I can't use bluetooth transfer if I'm in wifi hotspot mode...
Anyone got any tips, before I format the netbook and install Windows?
