Help connecting android
gravecad
Hi,
How can i connect my zenithik ZT-180 android to a computer? Why does it connect to a computer. Does it run more software?
The cable for my C71 is a standard usb mini that is available almost everywhere. The computer function is automatic access to mass storage device.
I have a zenithink zt-180, hookup the mini usb to you're zenithink and the full size usb to you're computer (it should download the driver if you're on the net). I use linux (openbox) it sees it as a mass storage device witch means it thinks it's a hard drive, so you can use it to transferrer files from one device to another. Hope this helps
