Help connecting incredible to computer?
lgbalfa
what steps do i need to follow to connect my phone to the computer?
i want to access my SD card.
the only disk that came with the phone is VZ access manager but when i installed it i could not locate the SD card.
thanks
Plug in the cable. You should have an option come up to either charge, sync, disk drive, or mobile broadband connect. select the disk drive option, and it will recognize and open the SD card.
I have autoplay enabled in WinXP, and i choose the option to open the folder to view files.
Go to settings, then click connect to PC, then check the box that says ask me. Then if it's checked when you plug into the computer it should come up with options and you can pick Disk Drive.
Ok im currently having this problem....no option pops up for me?
Im not sure what i can do....
Then hold and drop the notification bar down while plugged into a computer. the option should be there.
battery out, reset phone(it actually reset one time when i connected the usb cable), nothing.....
generally it just charges the phone. and thats it
the phone is charging as i see the lil "lightening bolt" on the battery icon.
but nothing at all pops up what-so-ever
It may not do it on it's own. Sometimes i have to open the drop down bar myself, and than click on the "charging" box", then it should open it.
