Help Connecting Infuse to Kies
lyst83
I bought this phone a few months ago and I am having a lot of trouble connecting my phone to my PC. When I connect via USB it gives me options such as Update with Kies, Mass Storage, and Charge. I pick update with Kies and nothing happens.
I downloaded the Kies program and it won't recognize my phone. It installed all the correct drivers (several times) and it still won't recognize my phone. Why did they put the option in there if my phone won't work with the program and the program won't work with my phone?? My real question is this: What program can I use to easily sync my files via USB?
Also, I have a secondary question. How do I save text messages from my phone to my computer?? My ex-husband has been harassing me over custody of our daughter and I need to print these text messages out or at the very least back them up on my PC in case something happens to my phone before we go to court.
There are thousands of apps in the market used for backing up sms. I use SMS back up and restore. Use this program and you should be able to print the back ups it makes.
Kies is frustrating, but I don't believe it works, it is a strange choice to give us if it doesn't work.
What files are you trying to sync to your computer besides that?
It's easiest I find to just drag and drop files onto/off the phone.
