Connecting multimedia doc via USB
Nepherim
If you decide to connect your multimedia dock to your PC via USB, you hit a re-boot cycle, which stops as soon as you remove the Droid from the dock. Anyone else get this?
~ ~ Dave
Okay, turns out this is not specific to the multimedia dock. For some reason my Droid reboots whenever it's connected to a USB port. Just plugging the USB cable in causes a reboot cycle. Unplug the cable and the reboots stop. I've tried two different cables, and two different PCs.
My guess is that I installed some incompatible software. Any suggestions, or anyone have the same problem?
I had problems with the Droid rebooting he first weekend I got it (day 1). Exchanged it on day 3 for a different one. No more rebooting...
Odd thing is it's been working fine, up until I plugged the multi-media mount into a usb port. That's when the reboots started. Now it happens even if I plug a normal USB cable in. Not sure if the multimedia thing is what caused it though.
At this point I'm just deleting app by app. Is there a 'hard-reset' category that removes all apps, but not other settings? I have no data to retain so that helps.
I'm about to get an award for most self-replies to a thread. Anyway, I ended up doing a hard-reset -- that fixed the problem. Now if I find the app that caused this...
