Charlesleonard
Member
is anyone else having problems connecting their Tab 2 to their PC? I have downloaded the latest Kies and still can't get the PC to recognize the device.Any Suggestions?
others may be better able to talk you through this , but this is what I did. By the way I have a Windows 7 PC. Connect your Tab 2 to the pc using the usb . at that point your pc should indicate it is loading the "new device found" drivers. It took a log time on my machine. Once it is finished you should be able to see both the external sd card and the internal memory called sd drive. If this acts correctly then you should be able to transfer files from both the internal memory and the external sd card and from and to your pc.Hi, Charlesleonard,
Would you like to share the connection process with me, I still get confused.
for some reason some pc's even though they have usb 2.0 it keeps telling to plug into a dift port for faster speeds. Samsund refuses to acknowledge it or try and troubleshoot
Hopes this helps
JC
