ajdroidx
Android Expert
Curiosity got the best of me and I did some digging around. Personally, I have come to the conclusion that big red, ehhem, Verizon, is not all its cracked up to be, well, I guess they are, but due to their backend and samsungs choice of radios = problems.
I have heard that samsung radios suck, something from the droid charge era, I think. Since the nexus was my first samsung phone and was pretty much a disaster from a phone and data connectivity stand point, it left a bad taste in my mouth. I am not posting this to slander or what not, its just some dot connecting I have done and thought I would share.
For a while now I have heard, even from verizons CSRs that samsung has some bad radios, I guess they switched to the VIA Telecom CDMA chips, which, from my understanding have a weak signal to start with. Couple this with the chip needs to dual broadcast to make the signal work!
Lets start here:
Samsung Drops Qualcomm in Favor of Via Telecom for Droid
The Nexus (CDMA) also uses this chip:
This article really help me put the dots together here: The Radio Performance Disparity of the Galaxy Nexus on GSM and CDMA - Mobile Central - Binary Outcast
I thought ifixit would have a teardown of the verizon CDMA version of this phone, but I could only find the GSM. Doing a bit of googling it seems the verizon s3 also has the same VIA Telecom CDMA chip in it.
Going back to the mobilecentral page, I find it really interesting that:
So, when one don't work, they both don't work. But the most interesting thing I read on that article?
This:
Now, once again, I don't have any direct proof, but to me, it seems there is an issue between verizons LTE CDMA backend, and samsungs choice of radios.
More info: Galaxy S III vs Galaxy Nexus vs Razr Maxx radios
Well, the SIII here seems to be doing a decent job, well, yeah, so do some CDMA Gnexs. Mine does a fine job when its near a tower but at home and work, yeah, it don't work so good and struggles to maintain a constant connection, just as other users in the sIII verizon signal thread have mentioned. Fringe area? No way.
I guess the VIA telecom CDMA chips are good provided you are near a strong signal since they seem to be weak, otherwise.
The fact that the VIA chip has to be connected to both signals? One goes out, they both go out = signal flipflop if either signal is not there. Modulation issue from the tower? Something out of synch? Im not sure, but this kind of explains a lot to me.
Once again, not trying to start anything, I just found this interesting and thought I would investigate and maybe figure out all the inconsistencies from all the verizon samsung devices.
EDIT: I forgot to add in a link, so here it is:
http://rootzwiki.com/topic/25921-this-is-why-your-verizon-nexus-signal-sucks/
Lets start here:
Well, the truth is, CDMA/LTE devices require both radios to be active and connected.
This:
The bridge between CDMA2000 and LTE is rather brittle and is prone to failure, because LTE wasn't designed to be bridged with CDMA2000 like that. It was intended to be installed alongside GSM and WCDMA networks, and it handles it a lot better with those networks. So when something goes wrong in the rather terribly buggy CDMA system, the whole phone can and usually does fail. If Verizon Wireless had upgraded the CDMA2000 system to UMTS HSPA+ like most other CDMA2000 carriers across the globe, it would have avoided dealing with this problem.
